Intake Manifold Gasket Replacement help
Old Jul 26, 2010 | 03:14 PM
maxellfullmoon's Avatar
8th Gear
Default Intake Manifold Gasket Replacement help
I need to replace my Intake Gasket on my 90k mile 2000 Discovery. I need to do this in one weekend so I was wanting to ask someone who has done it what all I will need to order to do this job.
I found this earlier post https://landroverforums.com/forum/sh...=intake+gasket
Is this all I will need?
Thanks
Max
Old Jul 26, 2010 | 03:47 PM
Bundu's Avatar
Banned
http://www.landroverresource.com/ Get RAVE, read.
Replace the throttle body heater, they fail as a rule. Check the thin plastic throttle body heater hose, they also fail.
Are you replacing spark plugs wires? You may as well if you are taking the IM off.
You can get a set of 8mm Kingsbourne wires https://www.kingsbornewires.com/
Old Jul 26, 2010 | 09:09 PM
vandev's Avatar
Default you can do it...
i tore my 04 down to the block in 6 hours with a home depot socket set and a few attachments and it was 96 out side in the sun. You should be able to do in a day...
Shryan
Apr 1, 2013 08:53 PM
Scott Weiland
Dec 30, 2012 09:58 AM
rick.miles
Aug 9, 2012 06:56 AM
jasonabarrett
Jun 26, 2010 09:08 AM
jbriggs
Jul 14, 2006 01:07 AM
