Just bought my 1st Disco.....
Little background on me..... I'm 24 and have been mostly a muscle car guy but have been into 5.0 mustangs this century. My cousin has a 99 Disco II and it has grown on me. So when I had a chance to get a 96 disco at a steal of a price I couldn't pass it up. It's a grey, automatic SE. Things I plan to do soon:
- Convert to DII taillights
- Exhaust, muffler at the least
- 2"-3" lift
- Rims and tires
- Convert to 99+ lug pattern
- Fender flares (Use DII if possible)
- New shocks
- Fix the rear side window that falls down
- Fix power steering leak
Any flaws in my list above? Anything else I should do?
Is converting to the DII tail lights and lug pattern doable? I'm guessing I'd use a DII rear axle and spindles, rotors and brakes for the conversion. Will that work? Is there an easier way?
How much wider is a DII's wheels set apart than a DI?
-Johnnie
- 2"-3" lift
- Rims and tires
- New shocks
-Johnnie
Well nothing from a DII will fit a DI and vise versa.
The DII is wider, the wheel base is the same but the axles are wider as well as the body, the body is also longer.
Well, end of story, no go on using DII parts on your DI.
Same exact block and heads but thats it, different intake, ECU, everything.
Does that answer your question?
Back to the drawing board.
