Key fob debacle: the adventure continues...
kept it on a charger for 2 days last week...didn’t make any difference, still had to use a key each day for the first unlock.
I swear, I believe it is some kind of lock function in the BCU.
it doesn’t make sense to me that it is a “lost” ground, or else it would be intermittent and erratic....but I’ve been looking.
could it be the under dash fuse box....again; it just seems irrational. If it were a symptom of that problem....why am I the only person (that I know of) in the history of the ownership of the model to have this problem.
is it the BCU....I think so; but I am not sold on the idea that it is a malfunction...I think it is a setting that can be edited.
but....I’m 54 years old, and I’ve been wrong before.
doc
nope, disconnecting the battery has no effect on the reset period.
doc
doc
I am with you, I think it is a security settting - obscure to be sure, but likely something you enabled when programming the key.
Soo I just found this
TECHNICAL INFORMATION No: 86/01/01/NAS
KEYS FAIL TO UNLOCK VEHICLE AFTER SITTING OVERNIGHT
A vehicle parked in a radio-signal-rich environment with RF noise at or around the same frequency as remote plips – 315MHz – such as garage door openers, house alarms, gates in gated communities, or radio transmitters may exhibit the symptoms. Not all vehicles exhibit this condition. Low ambient temperatures can make the condition worse.
· Vehicle is within the VIN range YA260032 to 1A703319
· 1999 vehicles with 48K replacement BCU (YWC000010) OR replacement RF receiver (YWY100450L) fitted.
· Vehicle plips occasionally stop working after sitting overnight, or for an extended period.
· When mechanical key is used to unlock the driver’s door, plips start functioning correctly again.
Great find. Where did you find it btw?
I *really* would love an archive of all TSB's on these Disco's. All of them... Anyone know where or how?
(the last 2 issues w my truck were actually solved with TSBs and I spun my wheels for a good while until like this, I stumbled on)
Kiss *** at a Landy dealer might get you access to the tsbs.
nashvegas (10-10-2020)
There are no WIFI signals at 315mHz... But here is what a quick google brought up...
Could be the doc lives in an area with a military base?
267 - 322 This band is allocated for exclusive Federal Government use. Operation of unlicensed Part 15 Devices is permitted between 285 and 322 MHz.
Pretty sure my HAM radio can listen to 315mhz and surrounding freqs.
Lots more spurious wireless emissions than when the trucks were built #5gdeathbeams lol
