-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   key stuck in ignition (https://landroverforums.com/forum/discovery-ii-18/key-stuck-ignition-31814/)
Classklown90 Jun 15, 2010 05:28 PM
My key is stuck, how can I get it out?
Spike555 Jun 15, 2010 05:40 PM
Using a small flat blade screwdriver pop the trim piece off of the top of the gear shift knob.
Tighten the nut.
Remove key.
Your truck is not all the way in park because your shift cable has stretched and needs to be tightened.
Classklown90 Jun 15, 2010 06:06 PM
So is that usually the problem? As soon as I'm done work I'm goona try this
Spike555 Jun 15, 2010 06:10 PM
Yes, 98% of the time on a DI that is the problem.
honda50r Aug 6, 2011 03:33 PM
Hey Spike, check your inbox. I'm chasing this problem down
Rovin4life Aug 6, 2011 03:59 PM
Actually if it is actually really stuck and wont come out and the vehicle doesn't come out when you release the ignition cylinder from the steering column then just have it rebuilt by a locksmith. Oh and take off both parts of the upper and lower cowl and use a long flat screwdriver or a chisel and bang on the shear bolts that are in and then bang them out until they loosen up and take out the ignition switch.
takes all of ten minutes to pull out the ignition switch to take to a locksmith.
LRD2&ME Aug 6, 2011 05:16 PM
My key gets stuck at least twice a week. Not sure if this has anything to do with anything but it works for me. I open my drivers door and push in the little door switch. Works everytime for some reason.
Spike555 Aug 6, 2011 07:05 PM
In the DI tech section there is a "how to" on how to rebuild/repair a ignition switch.
grandkodiak Aug 7, 2011 09:15 PM
i got mine stuck in my 00 disco when i first got it, could never reproduce it but it kept happening. i pb blastered then graphite lubed it up ever so lightly, and didnt change the rate of occurance. then someone mentioned the switch on the shifter doesnt like limp wristed push into park... i give it a good solid push into park and havent ever had it get stuck in the ignition since then. not sure but maybe you have the same or simliar glitch?
hilltoppersx Aug 8, 2011 07:36 AM
you don't wanna know where i got mine stuck
