knocking on 2000 disco 2
Old Sep 7, 2010 | 08:04 PM
Euro187's Avatar
4th Gear
Default knocking on 2000 disco 2
I bought a 2000 Disco 2 and everything was fine untill it started knocking. at first i thought it needed oil so i would put oil and then the noise would stop. i had that prob. for about a month untill my brother blew the head gaskets. we replaced the gaskets and put new heads. put everything back together and guess what? the noise is still there. i rand it with out the valve covers and there is no oil pumping. checked the lifters and they were dry. pump is pumping, checked the pick up i just dont know what else it could be..........=(
Old Sep 7, 2010 | 09:56 PM
ewok's Avatar
Edit for misread.
Old Sep 8, 2010 | 10:12 AM
NiteTrain's Avatar
Originally Posted by ewok
Loose bolts on exhaust manifold? That is the issue with mine.
how would loose exhaust manifold bolts cause it to have no oil flow to the lifters?
sounds to me like you have plugged oil galleys, put a can of seafoam in, run it, change oil, repeat until noise stops
Old Sep 8, 2010 | 05:56 PM
Euro187's Avatar
4th Gear
well i
know for a fact its not a loose bolt, as far as the sea foam i tried it and it didnt work i really dont want to run it to much i dont want to mess anything up.
Old Sep 8, 2010 | 07:01 PM
You need to do a oil pressure test.
Just because you cleaned the oil pickup screen does not mean the oil pump is working.
mowensmd
Aug 21, 2024 11:07 AM
SaltyRover03
Dec 19, 2011 07:31 PM
whatismyusername
Aug 18, 2011 12:52 PM
yellowlablounge
Sep 21, 2009 09:18 AM
disco1
Mar 3, 2006 10:29 AM
