last 3 months of DiscoII problems
1. Front differential went out and was replaced
2. Front drive shaft went out and was replaced 3. Crankshaft position sensor & coils replaced 4. interior fuse box went out and was replaced with used on, it has different issues so still need a brand new one. 5. replaced oil pan gasket, valve cover gaskets because they were leaking 6. replaced transfer case gasket because it was leaking 8. Alarm is malfunctioning, only drivers & rear door locks work now (this pre-existed 3 months ago) 9. truck just overheated and boiled out, now there's no compression so I assume it's the head gaskets or the heads themselves. 2002 Disco2 126K I bought the truck 1 year ago, no major problems till 3 months ago, are these all normal things to go out within a certain milage range or maybe the Texas heat? |
Some are like items 1, 2, and 3 the rest are sort of normal, hope you do your own work.
I do my own work, but the amount of time I've spent bent over or under my engine recently is a little more than I bargained for on my daily driver.
Thanks |
