last 3 months of DiscoII problems
Old Jun 19, 2011 | 06:41 PM
droland@teksinc.com's Avatar
Default last 3 months of DiscoII problems
1. Front differential went out and was replaced
2. Front drive shaft went out and was replaced
3. Crankshaft position sensor & coils replaced
4. interior fuse box went out and was replaced with used on, it has different issues so still need a brand new one.
5. replaced oil pan gasket, valve cover gaskets because they were leaking
6. replaced transfer case gasket because it was leaking
8. Alarm is malfunctioning, only drivers & rear door locks work now (this pre-existed 3 months ago)
9. truck just overheated and boiled out, now there's no compression so I assume it's the head gaskets or the heads themselves.
2002 Disco2
126K
I bought the truck 1 year ago, no major problems till 3 months ago, are these all normal things to go out within a certain milage range or maybe the Texas heat?
Old Jun 19, 2011 | 07:34 PM
Some are like items 1, 2, and 3 the rest are sort of normal, hope you do your own work.
Old Jun 19, 2011 | 09:47 PM
I do my own work, but the amount of time I've spent bent over or under my engine recently is a little more than I bargained for on my daily driver.
Thanks
Cleverjoe
Nov 5, 2013 09:22 AM
whurst79
Jun 11, 2008 05:06 PM
chris@wdainc.org
Oct 18, 2007 06:49 PM
lscjjc
Sep 2, 2007 10:52 AM
Rob V.
Dec 14, 2005 03:27 AM
