Lathe project ideas?
Old 07-02-2020, 09:51 PM
greisinb's Avatar
Default Lathe project ideas?
For a summer course I’m taking I need to come up with a CNC lathe project. Everyone does “bullets”, boring candlesticks, and chess pieces. I thought it would be fun to do something fun/functional for the Disco. Any ideas for something small-ish that could be machined out of aluminum? Maybe some part that always breaks because it’s made of plastic or maybe some sort of specialty tool even?
Currently my top ideas are the oil filler neck and some sort of **** for a future CDL mechanism.
Old 07-03-2020, 08:13 AM
XRAD's Avatar
remote coil mount. perfect for CNC mill project...but not CNC lathe.
Old 07-03-2020, 03:58 PM
Extinct's Avatar
Received 1,503 Likes on 1,066 Posts
Door lock pins are obvious solutions. SAI block off fittings could be interesting. BWM wheel adapters?
greisinb (07-03-2020)
Old 07-03-2020, 04:14 PM
BeardedRover's Avatar
5th Gear
Here's an idea, it would be cool to figure out how to make a coolant bleed screw that has a shut off valve and a nipple to put a 1/4" hose on top to properly burp the coolant without splashing it everywhere. Just a thought. could be easy enough to turn up.
The following 2 users liked this post by BeardedRover:
greisinb (07-03-2020), XRAD (07-04-2020)
Old 07-03-2020, 04:15 PM
5th Gear
Something similar to this but threaded properly and smaller as to not hit the hood.
Old 07-03-2020, 05:30 PM
greisinb's Avatar
Do you mean the pins that are in the check strap that give a loud crack when I open my door- because that's a good idea but perhaps too simple for what the prof might be looking for (but I will keep it in the back pocket because I'm sure I'll be making more stuff).
Old 07-03-2020, 05:33 PM
greisinb's Avatar
This is intriguing, I don't need to maintain my coolant system as much as I used to (thank god) but I'm sure ill be back in there soon enough and something like this could be handy.
Old 07-04-2020, 12:12 PM
Extinct's Avatar
The pins that go from the door lock cylinder to the lock mechanism
https://carrs4x4.com/products/land-r...etime-warranty
Old 07-04-2020, 01:02 PM
Discorama's Avatar
Can you do brass? AN-adapter for the oil/trans coolers would be cool.
Old 07-04-2020, 01:17 PM
greisinb's Avatar
Yeah, I can do brass. I looked those up and that geometry is totally doable. Forgive my ignorance but what would that adapter be used for in regards to an oil/trans cooler?
Quick Reply: Lathe project ideas?
