Leaks at the sunroof!!!
One of the most common issues with these trucks; there are dozens of threads about it on this forum. The sunroof tray drains break so the rain leaks into the liner instead of being routed away.
You may need to remove the headliner in order to do a full repair, as it will probably involve removing and repairing the sunroof trays.
Mine does this too, even after I put some sealant up there. I don’t use the sunroofs so a full repair is relatively low on the priority list but had to stop the leaks because I live in famously rainy Washington. My temporary solution was to buy a sheet of 3M automotive grade vinyl and slap it over the whole sunroof. It’s held up pretty good so far over 2ish years, maybe a little too good as I never seem to be able to make a full repair move up on the priority list! One day...
Its common for the water to get in because the sunroof frame is no longer sealed on the metal roof, as well as the actual seal under the glass in not fitted in place correctly letting water pass, if you want to do the job correctly remove the headliner, remove both front and real sunroof frames reseal them on the out side, make sure the drain are not blocked tie wrap the hoses into the inside frame, recover your headliner if it needed /or just strip and paint it, the refit it all back job done
did mine last year.....
H Hill (09-27-2021)
bcolins
10-13-2015 02:05 AM
