Left Front Axle Seal FTC4822 Install Orientation
Old Jun 1, 2013 | 01:49 PM
mpanoussi's Avatar
Default Left Front Axle Seal FTC4822 Install Orientation
My Land Rover Discovery 2 Left Front Axle Seal has been replaced twice and it is still leaking since I recently acquired the truck and I am convinced that the seal was installed by the previous owner in reverse, however I am looking to the you the confirm the install orientation.
Is the seal to be installed in Direction #1 or #2?
Thanks...
Old Jun 1, 2013 | 01:54 PM
mpanoussi's Avatar
Default Is the seal to be installed in Direction #1 or #2?
Old Jun 1, 2013 | 04:20 PM
Bryan H's Avatar
Unfortunately, I can't answer your question, but hopefully someone will.
I can say however, if you determine it is installed correctly and your leak is small (like 2" diameter overnight), try Blue Devil stop leak. It 'seems' to have stopped my minor leak, but I'm only 1 week in with the treatment, but so far so good.
Old Jun 3, 2013 | 09:38 PM
mpanoussi's Avatar
Default Front Axle Seal
That's interesting, has no one replaced an axle seal on this forum?
I even called British Altantic and they can't answer my question. The Rave manual has no mention of the direction of the seal.
Old Jun 4, 2013 | 05:57 AM
drowssap's Avatar
I be guessing but I would say #1, only because I cant remember ever putting in a seal where I could see the tension spring after it was installed.
Old Jun 4, 2013 | 09:02 AM
If you follow the logic of an oil seal, the rubber seal needs to be facing into the fluid of the axle tube.
Old Jun 4, 2013 | 01:31 PM
toad2's Avatar
I replaced the pass side as Mike and Drowsapp said, spring in. Sadly, still leaking.
Old Jun 4, 2013 | 03:21 PM
If it is still leaking, did you inspect the inside of the axle tube assemble for wear and or discoloration?
Old Jun 4, 2013 | 08:11 PM
toad2's Avatar
Well, i remember cleaning it up and looking in there with out any real knowledge of what i was looking for. Looked ok, installed new seal and put it back together. Doesn't leak much but it isn't dry either.
Old Jun 5, 2013 | 06:19 AM
drowssap's Avatar
is it leaking around the axle tube and the seal or the seal and the axle shaft?
