Lift time! questions re: SLS
Did you get the +2 shocks? If so, you should put +2" lines in at the 4 corners. If you need to replace the 4 lines, it would be a good time replace the two jump lines since you have to bleed the system.
When I replaced my jump lines, I ran into corrosion issues that stripped two of the fittings on the steel lines. One line I replaced and the other I replaced the fitting and reflared the end.
You can also make your own spacers for the crossmember. If you search, you will find that some people remove it and others have modified it. I haven't done anything with mine yet. But, when I do, I will make sure to soak the bolts in PB Blaster before I do.
Guess I was just ranting about not being advised of this on the phone when I ordered the lift parts. Rant over, had my dose of wiskey. :-)
smokin
Sep 6, 2013 01:19 AM
