Lifting my disco
I want to put a body lift or a bigger suspension on my stock disco. for looks and for bigger tires and ground clearance. Im having trouble finding the right tire though. Id like to use my stock 15" rims and put a bigger tire on it, maybe a 31'. How big of a tire could i use with a 2' body lift. Any recommendations?
I think theyre 18" with 28" tires. On www.rovertym.com theyve got 2"-5" lift springs, if i just replaced my current springs with those will that give me the desired lift? For me, the bigger the lift the better, tires arent a problem im getting any pair i choose for free, so the bigger the better.
How much lift do you want? At 3 inches and above you'll need to start adjustments to drive shaft angles, longer brake lines, steering... You'll have a bigger selection of tires if you go with a set of 16" wheels, and you should consider replacing the shocks too. You could also go with a complete kit from Cerrone's. There's lots of posts and threads here about your options for a lift too.
on
You may want to think this out a lot. That big a lift is going to cost you in extra parts as mentioned including drive shafts, front radius arms rear suspension modifications and lots and lots of gas with the larger tires. Are you ready for a 2 to 3 MPG fuel drop, how about the replacement of both diffs and axles when they fail because of the bigger tires.
What is it you want to use the truck for?
Second, don't go to a body lift, replace your springs, otherwise you will be very top heavy.
discos have radius arms? Can somebody post a pic? I'm curious to see how they are set up. I haven't seen anything come stock with radius arms since late 70's model fords.
on
Cheap doesn't mean good or correct. You try and lift the body, while still running your warn out factory coils and that truck will be all over the road, including it's side when you get a little off camber and roll. To run a body lift, you need HD springs and shocks.
By the way, either will make you more top heavy, but at least with the new coils you have more suspension strength to control the roll.
ORIGINAL: okdiscoguy
NiteTrain: do you not have a Disco?
Lifting is not cheap. The cost of the coils and shocks is the least of it. I have moved to the Dico after being a Jeep guy for a long time. I have an XJ with 8" lift and 35's, I upgraded to that from my 3". looking back the 3" was the best buy.
You need to think of all the components that need to be replaced or upgraded:
coils
shocks
gears
driveshafts
steering
brakes
basically all bushings
control/radius arms
possibly clocking the steering knuckles
and of course the gas mileage drop
I am sure I am forgetting something but that is a start.
coils
shocks
gears
driveshafts
steering
brakes
control/radius arms
