lock not working
when i lock the doors the passenger door doesnt lock with it, anyone knows what to do or should i replace anything? thanks
lock actuator. ebay or roverlandparts.com
message me and I will help you with it. I will also make some suggestions that can save you a lot of money.
You can rebuild the lock actuator with a new 12v motor from Radio Shack.
any diy on how?thanks
Remove inner door panel, remove lock actuator, open actuator and remove the 12v motor, take it to Radio Shack and get a new motor, reinstall.
Pretty much that simple. Its the motor that goes bad not the lock. You might want to lube the gears too white white lithium grease. |
thanks spike555:) appreciate it. ill do it tom
Has anyone come up with an easy way to open up the actuators on a DII??
I just tried for an hour to get into one with no luck (girlfriends disco II). They certainly did not want anyone getting into that thing. If it were my truck I'd be a little bolder and grind the rivets out but it's not, so I won't. Maybe if she decides to get a new one I'll experiment with the old one.
Just came in to figure out how to fix the rear seat. Will post in another thread. |
