Looking for help reading codes, diagnosing.
![](https://cimg4.ibsrv.net/gimg/landroverforums.com-vbulletin/2000x1504/65d9ad0e_6c71_4109_9520_66c59a879007_479aa54530978430d0f7458af71d8a0f0b1b2b4c.jpeg)
![](https://cimg5.ibsrv.net/gimg/landroverforums.com-vbulletin/2000x1504/166c35a4_678c_499e_b0af_585d3c907977_33c2f4999f485a7d89963e67e6d2bc4152d2b84e.jpeg)
![](https://cimg6.ibsrv.net/gimg/landroverforums.com-vbulletin/2000x1504/b2ca700c_1a75_430f_aade_0d098c2892aa_9ea38434c194f186a0e235fa8413805aee4782d0.jpeg)
![](https://cimg7.ibsrv.net/gimg/landroverforums.com-vbulletin/2000x1504/114851a8_f7f8_4ab6_8b06_c60a6b30c5a8_a7fe53443c376621171d765d7e47cbacc5642b73.jpeg)
Hi everyone,
I have a 2001 Land Rover Discovery 2 with about 130,000 miles on it. The check engine light was on when I started it and started blinking as I went to leave my driveway. So I think oh **** I need to turn around and park this thing but it died the second I pressed the brake down. Went to start it up again..nothing. Didn’t try to turn over or anything. Gave it like 20 seconds and tried to start it again this time with no problem. Backed up into my spot and pulled the code.
Attached are the pictures.
I changed the spark plugs and wires a couple of days ago hoping that would fix the existing check engine light but no such luck.
I’ve been doing this as a kind of project and am hoping to be able to fix these things on my own. Part of the reason for getting the truck. But I definitely wouldn’t mind some assistance since I’m certainly new to this but am hoping to learn a bunch! If you could give me the beginner information you can make from it along with what I should be looking into that would be awesome.
Also, if you need anymore information please let me know and I’ll try to get that! Again, thank you!
Kelsey
Last edited by Kelseygough; 01-08-2019 at 12:12 PM. Reason: Also check engine stops flashing when stopped or idling.
P0300 is a general code.
P0308 pending is irrelevant at this point. It's already current.
If you feel frisky, you could do a compression test. Some mechanics swear you should do one first before even thinking about swapping parts or ordering parts. Me, I'd rather swap stuff around first.
Pull the plug and make sure its not wet with coolant, oil etc.
If its wet, with coolant. Pressure test the cooling system. Oil. you need (Insert deity of choice here).
Not wet, continue below.
Swap the spark plug with the next cylinder. (cylinder 8 with cylinder 6)
If the misfire moves to cylinder 6, its a bum plug.
Swap the spark plug wire with it opposing cylinder. (cylinder 8 with cylinder 7)
If it moves to cylinder 7, bum wire.
If it sticks with Cylinder 8 after swapping, I would go after the Coil. Swapping it with its opposing Coil is possible, its just a royal pain in the ***. But at 130k, I wouldn't lose sleep over replacing both
If the code sticks after that, then it may be an injector (wiring or hardware).
Hope this helps.
Hope this helps.
Hope this helps.
Hope this helps.
My guess is you have a bad plug wire or coil issue.
It depends. I've seen cars run down one cylinder and I have seen cars refuse to stay running down one. Could go either way.
