Looking for Owners Manual or RAVE CD?
(a moderator should pin this)
Download the ISO here:
http://tinyurl.com/jx6cu
After downloading the ISO, you have a few choices.
-Burn the ISO to a CD-R
-Open and extract the contents of the ISO using Winrar or a similar program
-Mount and utilize the image using Alcohol 120% or a similar program.
Burning the ISO to CD
If you're running NERO, you should be able to load a blank CD into your CD-R drive, right click on the ISO and choose "open with-->Nero Burning ROM". Nero will launch and walk you through the rest of the process.
If you're running Roxio EZ CD Creator, launch "Creator Classic" and find the option to "Burn Disk Directly from ISO".
If you attempt to create a new data cd and add the ISO to the CD project, chances are you're going to end up with a CD that has the ISO file on it, rather than the CONTENTS of the ISO which is what you want.
Open and extract the contents with Winrar
You can download winrar for free from http://www.winrar.com Download and install it.
Right click on the ISO file and choose "open with-->winrar" choose "extract" and choose a suitable place on your computer to put the contents of the ISO.
Mount using Alcohol 120% or similar program
If you have Alcohol installed, I would assume that you know how to use it.
HTH.
HTH.
