The 03 and 04 do not have chips either.
You can get a key FOB from this place in UK, will cost you only 180.00 and they send a key and programmer, you send the programmer back and they refund 30.00 and email you the EKA code. Remote Key Europe Remotekey Europe - Specialists in Key Fob Replacement, Immobiliser Bypass, Key Fob Repair |
I have an '03 SE and had my key copied for $3 from my local locksmith. It works in the doors and ignition.
Originally Posted by GARovee
(Post 169905)
Well.. What can I say? The keys grew legs and walked off. Looked for them all weekend. Thank god for google and a post on discoweb on how to hot wire a disco. Bought two micro switches and mounted them on the roof console right above the sunroof switches. One acc/run and one to start. A hammer and a flat head screwdriver unbolted the ignition switch and stiffed it up in behind the dash. Didn't cut a single factory wire or harness. No steering lock but hey I have push start now :) $39 got spent at bestbuy for keyless entry module.. So about 45 bucks total to fix a major f-up. Can go back to factory set up since I cut nothing and damaged nothing when ever I have a few hundred dollars for new keys and fobs and dealer programming.
Just buy a whole new ignition assembly from Lucky 8 for less than $80 and it will come with a new key.
Originally Posted by logan_gibson
(Post 749349)
Originally Posted by Range rookie
(Post 749417)
Thank you login_gibson, and i would be able to google Lucky 8 i assume?
https://lucky8llc.com/collections/di...tch-components |
right on ! login_gibson that worked out great with that lucky 8 and under a hundred bucks , what a deal and the satisfaction of knowing I'm not going to be cutting and splicing any wiring or harnesses so i thank you once again
anytime.
