low mpg's
RE: low mpg's
What year and how many miles? I have an '01 and the best I can get on the highway is about 18.5 mpg most generally around 18. My '95 gets a little less at around 16 highway, even after the most recent tune up. You must burn premium gas. There are a lot of posts here regarding spark plugs and wires to use. Anything over 2300 rpm on the tach you can figure about 1/2 mpg less per increase of 200 rpm. So at 72 mph you are probably at about 3000 to 3200rpm, so at 62 mph you will probably get closer to 16 mpg. Remember this is a full time 4 wheel drive vehicle, that weighs over 5000lbs.
RE: low mpg's
ORIGINAL: JayhawkinIdaho
BTW, I've never had the patience to go 65 mph for very long, so maybe my theory is shot.
on
RE: low mpg's
ORIGINAL: mwyrick45
i have an 03' with 60k on it. not sure when the last tune up was, but im about to do one, so well see after that. thanks guys
What octane gas are you running?
That roof rack will cost you an easy 1.5 MPG.
on
1 Post
RE: low mpg's
Do you live in a cold climate where the supply 'winter gas' ???
Warm-ups are a killer in the winter, because itstays much longer in the open loop mode, where it runs super rich until it reaches normal operating temps. And winter gas will rob you of at least 20% off your normal summer gas mileage.
I'm in Canada, and it is a very cold winter up here. You can't have a more up to datemaintenance wise Disco than mine. All was done within the last year, synthetics everywhere ,plugs, wires, new O2 sensors,tires inflated at 40 p.s.i etc... And with winter gas, I get about the same figures as you....And I have Yakima cross bars, no big roof rack. So if your situation reflects mine, don't sweat it...it sucks, but its normal !!
Classic89
08-10-2007 08:58 PM
