Lower windscreen seal/cowl
Old Dec 31, 2016 | 09:57 AM
  #31
jfintexas's Avatar
Originally Posted by Luckyjayb
Which remanufacter cowl would that be and how bad is the billet price wise?
Here's some links to a couple eBay items you might be interested in. I bought mine from Taiwan. Required a couple drill holes after placement and measurement but it's heavy duty and seems to be holding up well. I also replaced the A Pillar Trim using the same material and same eBay seller. This was after the recommendation of some other forum members. Mine was obliterated and neglected by PO.
99-04 Land Rover Discovery 2 WINDSCREEN WIPER COWL TRIM PANEL FASTENER SET PAIR. (This is if you just need replacement fasteners)
Land Rover Discovery 2 TD5 Windscreen COWL Under Panel Trim Plenum
Old Dec 31, 2016 | 10:16 AM
  #32
longtallsally's Avatar
I'm missing those fasteners on each side of mine...
Old Dec 31, 2016 | 08:33 PM
  #33
Luckyjayb's Avatar
Those are the same ones that Miami rovers has on eBay for like $195 I believe. No intake filter since its fiberglass and the Miami rovers already has the cutouts
Old Dec 31, 2016 | 08:40 PM
  #34
JUKE179r's Avatar
I was going to try to "fix" my cowl but its AFU. It's totally cracked in halves....
Old Jan 3, 2017 | 07:07 AM
  #35
number9's Avatar
Default Use Caution When Opening Hood
Originally Posted by JUKE179r
I really think it comes from the hood mounts when it's opened and shut closed and flexes the cowl assembly.
I noticed this earlier this morning when opening my hood in the dark. The key to prevent the flexing and possibility of cracking an old weather beaten cowl is to not over extend the hood when opening. If raised just far enough to deploy/insert hold open it will not contact the cowl.
LR screwed us on this one by not using gas struts or other hardware to prevent the damage.
There's a thread or two here about strut mods. May want to consider if investing in a new cowl.
Old Oct 25, 2018 | 03:47 AM
  #36
JUKE179r's Avatar
Anybody try using Flex tape over the crack in the window cowl?
I've used Flex tape for my rear cargo door handle since the plastic is weathered and cracked all to hell. The tape has held up nicely for 7 months now and was wondering if it would work for the cowl.
It might look ghetto but it'll keep some of the water leaking in.
Old Oct 25, 2018 | 10:31 AM
  #37
Richard Gallant's Avatar
I used some sheet plastic and and a JB Weld epoxy designed for plastic crack repair on mine.
JB Weld 1st and let it dry, a light sanding after to smooth it off
Attach the plastic, the squares were suppose to be face down oops
Some weight to hold it in place while drying then paint black
Chrisinhouston
Aug 13, 2013 03:30 PM
oysterhead
Jul 12, 2009 01:04 PM
mhaise57
Jul 5, 2009 06:29 PM
And4848
Nov 20, 2008 02:29 PM
