lube questions
Old Dec 13, 2010 | 06:18 PM
halfassedastronaught's Avatar
5th Gear
Default lube questions
I remember reading on here some time ago about rotella 15w40 motor oil....and a wix filter. Is this the right stuff to buy for houston tx climate. I just want to confirm before i change it. seems i remember alot of good comments about this oil and a wix filter. just wanna make sure its 15w40. and what the filter number was. 2003 disco
Old Dec 13, 2010 | 07:01 PM
lipadj46's Avatar
yes 15w40 is correct, you can also try the 5w40 synthetic. Wix filter is 1515 (or 51515 forget which), that is the larger filter.
Old Dec 13, 2010 | 08:16 PM
For TX you can use the 15w-40 year round.
Old Dec 13, 2010 | 08:42 PM
buick215's Avatar
You can also use the Mobil 1 301 oil filter, it is longer than the regular one.
Old Dec 13, 2010 | 08:49 PM
FightOnUSC79's Avatar
What would you suggest for AZ? it is basically hell for half the year so I'm looking to get the best protection possible.
Thanks in advance
Old Dec 14, 2010 | 08:21 AM
texmbr's Avatar
Went to 15w40 Rotella in both our Disco's and like it. In Texas good year round and great cleaning qualities.
Old Dec 14, 2010 | 02:51 PM
KyShark's Avatar
Any recommendations for Kentucky? It generally doesn't get below 0 here, though it might once or twice. Am also concerned about MPG... is 15w going to slow it down too much?
Old Dec 14, 2010 | 04:16 PM
texmbr's Avatar
I did not notice any loss of MPG at all with 15w40. Now I did when I switched to 75w140 synthetic gear oil in transfer case and diffs.
Old Dec 14, 2010 | 06:04 PM
lipadj46's Avatar
15w40 is fine for temps above 32F. Under 32F you will start getting some unhappy valvetrain noises. Personally I like using synthetic 5w40 as it is only $15 more an oil change but I live in Buffalo so there is no way I would use 15w40 in the winter.
Old Dec 14, 2010 | 08:27 PM
KyShark's Avatar
Pardon my ignorance, but does unhappy here mean harmful or just an annoyance? With a truck I don't have the service history for I'm liking what folks are saying about the detergent qualities of the 15w40 rotella.
