Lucky 8 Window Washer Pump
I recently ordered a window washer tank and pump from Lucky 8 after realizing how badly I needed it in Death Valley. I went to install them today and I couldn't connect the pump to any of the connectors that were near where the pump used to be. I thought I got the wrong part and so I called Lucky 8 and they said I had the right kit and the correct pump. I'm not sure if I need to modify the wires or the pump or If I'm missing something!
For what it's worth, none of the three pumps on my truck look like that spade arrangement on the new pump. Two of my connectors are the style of the connectors in your photos, and the third is a larger version of the same. If the pump physically fits the tank then I'd consider making two adapter wires rather than return the pump and hope for the best.
Brandon318
12-30-2020 08:45 PM
