M&S lights flashing, then limp mode, then dead
Hello,
About two weeks ago my D2's M&S lights started flashing on the dash. A day or two later they were still flashing, and the truck went in to limp mode.
I went out of town for a week, and when I came back the truck wouldn't turn over at all. Just clicked like the batter was dead.
New battery was purchased in April. No loose cables, everything looks clean. Was putting out 13.8-14+ volts on the ultraguage.
Current trouble codes: P0150, P0174, P1174
Any ideas as to where I should start looking first?
Thank you!
Nathan
Thank you!
Nathan
Start with the O2 Sensor first. If I can recall correctly, mine runs smooth and sometimes gets rough when idle. I have been using Bosch sensors but they fail plenty times. Not the best in my opinion. I wasted too much time installing and removing them and sending them back. The one set I got from Atlantic British long long time ago never had problems for many years and its not Bosch. Looked very generic sensors.
Seconded on battery. And/or battery terminals, ground cable. Clean the terminals and ground locations thoroughly. Make sure there's no rust or dirt preventing a good ground.
Alright, so finally getting around to addressing this. I attempted to start the truck and it was completely dead. After cleaning the terminals (pretty clean to begin with), I let it sit hooked up to my daily driver for 20-30 minutes. After a few tries, it finally turned over.
Still in limp mode, so I only drove around the block a few times. Ultragauge showed 14.53v.
The next day I went to drive it to my indy LR shop and it was completely dead again.
Any ideas?
Any ideas?
