Made your own bumpers/racks/ect.
i mad emy own roof rack and i must tell you that you have to think about how you are going to mount it first......
i made my rack and then spent another 300 bucks on mounting it and i know i wouldnt do it again
i had to custom make my own mounts and have a local company copy my orginal to make 6 identical copies..... not cheap...
anyone can make a rack or basket..... just think about how your gonna mount it.....i would buy a rack next time around!!!!
I'm looking to do both bumpers, rock sliders, and a full roof rack. I was going to base them off models I like that I've found online.
Front bumper: replace stock crap bumper with a steel bumper. I have the stock brush guard, and my guys say they could pretty easily cut and integrate the top part into a fabricated bumper. Also make a winch tray for when I invest in one.
Back Bumper: I like the 'Greg Davis' style one, and don't mind trimming the back panels (Disco's got enough *** that trimming some won't matter). However I've seen some that use the stock lights in different ways integrated. I like the idea of that because this is also my DD. I'm also making sure I integrate a tow hitch. I have an SD, and it came with little to no extras, and a tow hitch would be an almost essential addition.
Sliders: Gotta be better than the plastic crap that's on there. These seem like they'll be the easiest to do.
Roof Rack: We're looking at an 'Voyager/Safari/(the one that follows the roof line)' style. I like the models I've seen that have 2 platforms instead of a sloping line. Seems like it would be easier to make.
Is this a better explanation?
i plan on doing my own rack and front winch bumper (tube type) this summer when it too hot to be out during the day. For mounting the rack i was looking at these.
http://www.jcroffroad.com/Merchant2/...ry_Code=XJMISC
Worked great on my Cherokee but i dont know if the gutters are the same. I'll buy them and try i guess.
Dave
Dave
Those mounts are not tall enough for the Disco. Also you can have a local shop make some for you for about the same amount of money that will fit what you need.
I have made series of racks over the years and some desgins are far easier than others. A voyager rack copy is going to involve far more thought than a flat one. Now days when I build I always do a couple versions and prototypes before I ever really get to making the real rack. I will start with PVC and then nmake one out of cheap EMT and use the screw on connectors to see how it will work on the roof. Then once you gat it all right then you will have the right measurements and angles needed to make what you want.
The easiest way to attach a rack is to use a Yakima or Thule base bars and then just drill and put a bolt through it. It will be taller than you probably want though.
The reasons I have ever built a rack was becasue there was nothing on the market that really fit my needs so I would have to make it myself. I have some pictures somewhere so I will see if I can find them and then post them up.
I have a TJM 1/2 rack that would be okay to fabricate.
If you can cut, bend & weld you could do it.
if you want I'll take some pics over the weekend.
I fit it over the back - I have sports bars on the front. you could rework the design principles to make a full rack.
________
VAPORIZERS INFO
________
VAPORIZERS INFO
on
I will start off by saying that I have no welding experience. But my roommate and a friend both have fabrication experience. And they're both itching for a project for the summer.
As for pictures, send me your e-mail address and I'll send you some of what I did on mine.
