MAF sensor options (other than Bosch?)
I had a good 5+ year run with the current Bosch MAF sensor in my 2004 D2 HSE before it starting throwing MAF code (and a Bank 2 knock sensor, which I am assuming for now is related to the MAF code).
I tried to order a new Bosch MAF (complete, with housing) from a couple of vendors and each time got a housing that was a couple mm too small for my airbox and intake hoses.
Frustrated that I couldn't buy a complete Bosch MAF again, and not wanting to taking the MAF itself out of one of the undersized housings, I instead bought a different brand MAF sensor only that made it about 6 months before starting to throw codes (MAF and knock sensor).
Anyone have any suggestions of where I can get a properly sized Bosch sensor+housing or just a Bosch sensor (at a reasonable price)?
or lacking that, a different brand that you've had success with?
The housing for the 2003/2004 trucks is a different size to the earlier years. You may have been sent ones from the earlier trucks.
Some people have had success with non-Bosch MAFs, but it seems like the Bosch ones generally have a longer life than the others. Was certainly the case for me.
If off roading, keep a spare new air filter and check the one in use when you stop. If dirty, replace in with the spare.
I've never directly cleaned mine.
