pull the crank and regrind it
that is what i was looking for, I did not see that you reground it. i though you put standard bearing on a 110k mile crank |
Originally Posted by drowssap
(Post 457189)
Originally Posted by RoverMasterTech
(Post 457144)
Didn't matter if he crank was under or not. The customer wasn't going to pay 3k to pull the crank and regrind it. When you are repairing a customers 10 year old car it's not about doing it "right", it's about achieving a goal as cost effectively as possible. There is no guarantee that grinding the crank and putting in oversized bearings would net anything better than just replacing the bearings.
Money is always the limiting factor and if funds were unlimited they would chuck in a new engine. |
Agreed
(Post 457144)
Great write up
Thanks for all the info and photos. I wish I could find a mechanic like you here in the Los Angeles area.
"Measure twice and cut once"............it's one of my favourite sayings also and it is so true.........now even my wife quotes that saying:eek:.
It avoids so many 'cock ups' when in a hurry. :cool: |
Anybody have a parts list for this overhaul.
I already have my sump off searching for the root of my 8-9PSI hot idle oil pressure (accompanied by minor tick.) I didn't find any issues and minimal sludge in the sump so I'm considering digging deeper while I have it off. So far my list is as follows Buy up-front: Timing Chain Kit from AB ~$120 (includes sump, Front cover gaskets) Standard Main Bearing Set ~$80 Rod Bearings ~ $80 Rear Crankshaft Seal ~ $20 180 Thermostat (While i'm in there) ~$80 If necessary: Oil Pump gears $100 Two other questions: 1.) Will this considerably increase the expected life of my engine assuming proper maintenance/attention from here on out? 2.) I also have an oil leak in my valve cover gaskets. Is there any advantage to doing it all at once or should I get the bottom half done first? |
If necessary:
Oil Pump gears $100 this is probably the original problem with low oil pressure I would think it would be at the top of the list, long before bearings. |
Thanks for the valuable insight, I will be doing this on my rover in the coming months.
You wont be able to replace the rear main seal as it is one piece and slides over the crank shaft. They never leak anyway. you will HAVE TO replace the rear main cap crusifix seals.
