Maintenance question
Old 12-20-2020, 07:29 PM
RavenMocker's Avatar
Originally Posted by Richard Gallant
If you go this route have your heads checked and trued, if you are looking for ARP studs let me know I am pulling from a 4.6 only a few months old.
what would you be asking for the ARP’s?
Old 12-25-2020, 03:29 PM
Originally Posted by Extinct
You should sign up for mycarfax.com (free) and look at the service history. Very low probability at 152k that your truck has the original head gaskets. If they have already been changed they should be good for another 100k miles, particularly since you have changed the rest of the cooling system. You can also lay under the truck and look up at the engine, if the heads are clean and the block is oily, they have likely been changed. Third option, there is a small spot where you can actually see the headgaskets from above, if you can take a high resolution photo and post it I can tell you if they are OEM LR or previously replaced.
Either way I would not change the HG until needed.
Wow! That’s a nifty tool. It says both head gaskets were changed at the dealership at 32,000 miles. The radiator was replaced as well.
Old 01-01-2021, 07:00 AM
I’m not going to change the head gaskets at this time. I will replace the valve cover gaskets and for the plenum. I hope to have it all done and back on the road middle of the week.
The following 2 users liked this post by RavenMocker:
Richard Gallant (01-01-2021), The Deputy (01-01-2021)
Old 01-06-2021, 07:16 AM
Update: the issue with the Evap system as listed above. The smoke test revealed the problem. One of the lines was damaged. I’ve made the needed repair and a second and third test post repairs shows no more leaks.
The valve cover gaskets were both leaking. New ones installed after scrubbing and cleaning the valve covers.
Old coil pack removed and tossed to the side as an emergency part. Will be relocating soon. Will be pulling plugs and inspecting. They only have about 15K on them.
My AC compressor clutch and coil are bad. Replacing this soon.
Old 01-06-2021, 08:36 AM
mollusc's Avatar
Now that you've done the rocker cover gaskets, you should implement the PCV mod to reduce the pressure inside the engine, and slow down the formation of any new leaks. There should be info in the stickies at the top of the D2 forum.
Don Neville
03-09-2022 10:20 AM
Tristan Stumpf
11-20-2019 02:49 PM
Imi39
09-09-2019 11:27 AM
Jeff NYC
07-28-2019 11:18 AM
vishrb
02-14-2011 12:27 PM
Quick Reply: Maintenance question
