Major brake problem
Old 07-11-2018 | 04:58 PM
dasherman's Avatar
Default Major brake problem
Took the 04 with 122k miles on it to get pressure bled. Truck came back 10x worse and had to drive it through town and back home using the ebrake. He must have screwed up.
Air is definitely in the ABS and there is a brand new MC on it. I tried bleeding the brakes the old fashioned way (two man job, tighten when pedal is pressed to the floor) and nothing comes out of the rear lines and only sparse amounts of fluid come out (after 10-15 pumps in sets of 4) from the front lines.
I have replaced all calipers and fluid is clear. Any suggestions on how to tackle this?
Thanks guys
Old 07-11-2018 | 05:03 PM
redrover75's Avatar
Did you fire the ABS?
you wont get all the air out without getting the abs to activate.
Old 07-11-2018 | 05:08 PM
dasherman's Avatar
No, but I'm getting a delphi ds-150 in the mail soon. I plan on using it immediately. For now, I just tried conventional brake bleeding and made basically zero progress. Booster, MC, and lines are all fine so it can't be any of that. It has to be the air in the system or dirt but I can't figure out why it's not even pushing hardly any brake fluid out...
Old 07-11-2018 | 05:45 PM
Red5's Avatar
Thanks guys
That doesn't sound good. Even with air in the ABS unit, you should be able to easily push fluid out of the bleeder screws. You say the MC is new, did your guy replace it during this job?
Old 07-11-2018 | 06:05 PM
dasherman's Avatar
Yes he replaced it. Brake pedal was not good but it was not non-existent until after he 1. power bled, 2. new MC, and 3. did a bunch of **** i don't know, such as cracking open the ABS lines and trying to manually bleed it (without my permission or knowledge of him doing so). Now it is completely gone.
I just tried to bleed the front driver's side and now no fluid comes out at all.
Something is seriously wrong and I don't understand what it is.
Old 07-11-2018 | 08:23 PM
Red5's Avatar
IDK, never had the problems you describe but sounds like the ABS may be FUBAR. Weird that you can’t get any fluid through the lines. Not being a smart ***, but the reservoir is full, yes?
Old 07-11-2018 | 08:45 PM
dasherman's Avatar
yes it is lol
Old 07-11-2018 | 09:57 PM
redwhitekat's Avatar
What kinda shop would let a truck out of their shop in this condition ??
Old 07-12-2018 | 12:46 AM
Richard Gallant's Avatar
This not helpful but there is something seriously wrong, even with ABS disabled and the ignition off you should get fluid out. Brakes are not rocket science, they are basically just a pump.
My bet is the master cylinder is pooched - it is the place to start.
Removing lines from the modulator is not bad to get out just take your time and be gentle removing and replacing, to avoid cross threading.
It is messy but try removing the brake lines from the Master at the ABS modulator (rear two lines on the Modulator) and pump the pedal (have something to catch the fluid). You should get fluid when the pedal is pumped, my bet is you will not.
If you do get fluid try bleeding only the left front, even with air in there it should get clear pretty quick. But have someone watch your brake fluid, if it is not going down you have the bigger problem.
If this fails check the modulator output lines
Put a bunch rags around the modulator and just crack them open a ways,
one at a time, pump the brakes and fluid should come out.
If not that is a big problem in fact you should have the 3 amigo's lit up, because the modulator would be blocked somehow. Check all your electrical connections to the modulator as well just as a bit of extra insurance.
The other possibility is if he removed lines from the modulator he did not get them the back in right place. Should be impossible but you never know.
I can not believe anyone can screwup replacing a master cylinder on one these it is dirt simple 2 bolts and 2 hard brake lines.
shanechevelle (07-12-2018)
Old 07-12-2018 | 07:41 AM
shanechevelle's Avatar
I agree with the above.
Take the lines off the master and see if you can pump fluid out.
I was going to suggest taking a bleeder out and letting it sit to see if you get any fluid out.
