Major Service.
Disco Mike, I recently got an 01 disco 2 at 150 k miles. We were planning on using it to go to Texas for thanksgiving, ( I live in the springs) I have only around 500 dollars to spend on service expenses before our trip, what do you recommend I service immediately and what can be waited on until I return and get more money for the rest of the recommended service?
sorry for the thread revival but i am buying a 2004 discovery se w/ 44k miles on it... maintained well. all services done up to date. most recently plugs and packs. new tires and battery. what else would need to be inspected or see if it was already completed?
You'll hear more detail from those more familiar than me, but a head gasket job, (80k miles), 3 amigos prevention, And the self leveling suspect suspension are common issues with this vehicle. .
I have an 03 with 83k mi. and I'm in the process of making my way down the Disco Mike list. I am finding that it isn't THAT expensive if you like to turn wrenches a bit and work on your own car. I started with plugs and wires because I had to. Next, I plan on doing the differentials and transfer case, followed by tranny filter and fluid. Yours has very low miles but I consider getting these items done because that fluid breaks down over time too... Do you know if you have a driveshaft with greasable U-Joints? I know that's an issue with mine. Sorry to go on too long. That's my advice - prioritize the items and do the list in your own time.
For those of you buying a used vehicle with 60K or more on it, consider doing the full list to bring your truck current.
1 Oil filter, K&N 3001 or Mobil 1- 301
1 Factory air filter
6 Qts. of engine oil, Shell Rotella T-6
2 feet of 3/16th vacuum tube
2 feet of 5/16th vacuum tube
6 Qts. Of Vavoline’s high mileage Dextron 3 ATF
7 Qts. of 80/90W synthetic gear oil, 85W/140 for HD use
3 Pints of Castrol Synthetic or Vavoline’s DOT 4 Brake fluid
4 Qts of synthetic Power steering fluid
2 Gallons of Peak or any green or yellow coolant, don’t use Dexcool
1 Bottle of Lucas Power Steering additive
1 Bottle of Lucas Transmission additive
1 Can of B&G’s 44K gas additive
1 Can of Spray Carb. Spray
1 Can Of Brake cleaner
8 Spark Plugs, I use Bosch Platinum Plus 4's
1 Set of Magnacor or STI 8mm plug wires
1 Serpentine belt
2 Bottles of SeaFoam gas additive
1 T/Stat
1 bottle of WaterWetter or Purple Ice
Hoses and belts, as necessary
60,000 Mile Service or Major Service for High Mileage Used Vehicle just purchased
Bleed the brakes
Flush and change the power steering fluid adding one bottle of additive
Service the tranny adding one bottle of additive
Change the coolant Pressure Cap and t/stat
Do an engine flush before changing the oil
Do an induction cleaning
Clean the throttle body
Add fuel additive to full gas tank
Change both of the diffs fluid
Change the t/case oil
Replace the plugs and wires
Replace the air filter
Lube all the drive shaft grease fitting including the 2 slip shafts
Do full inspection of brakes, hoses, bushings etc.
Rebuild or Replace the front drive shaft if it only has 1 grease fitting
Hopefully I didn't leave anything out.
1 Serpentine belt
1 T/Stat
Bleed the brakes
I bought 2001 Disco a few months ago (can't seem to post a picture of it, admin rights?) Completed most of the list provided by Mike. Found out the hard way on the drive shaft. Bastard blew when making a turn and nearly took out my fuel line. Luckily I was only driving about 15 mph. I ordered an DS from Lucky8, and it's been working great since.Cracked the transmission case housing a bit; JP welded it. There is some visible ATF leakage but only a few drops. When I changed the ATF I didn't change the gasket or filter; plan on doing that this weekend. Now onto some other issues...did a spot check of my spark plugs and found that the 5 and 7 were a tad oily. Anything to worry about here? A head gasket issue? I've noticed some heavy oil seepage coming from both the passenger and driver side head and running a trail down towards the sump. Not a whole lot makes it to ground but there's enough accumulating on the axle and steering damper to take notice. Any chance coolant is getting into one of the cylinders. Having some issues with power. Was running rich until I replaced O2s, plugs, wires, MAF, and air intake filter. All codes thrown before were resolved, not have shown in several months. Live data seems to show it's running fine. However, the power issue puzzle me. Need to replace the cat converter; one just arrived today from rovers north. More important is I need to figure out what killed the cat converter. Do oily spark plugs and slow loss of coolant point a cause? Will be replacing t-stat and hoses this week as well. Like I said, it's been losing coolant slowly, but no sign on ground. It may be from the top hose bleeder valve failing (duct taped it temporarily; not overheating issues). Any thoughts on where I should go from there?
Ok, I am not mechanically inclined , at all. Have bought a 04 SE with 46,000 original miles which is in good shape. I want to keep it that way and understand the need for proper maintenance. If you will give me an ideal as to what a reputable shop would charge , or range , for this work. Thanks George
BUT, Rovers are VERY easy to work on.
Buy a $99 mechanics socket set from the Home Depot or Sears and you'll be able to do 90% of maintenance/repair on your own.
You owe it to yourself (and your wallet) to at least attempt the work. There are lots of pictorials and videos on how to do this work on the interwebs.
Rovers are no different than any other car, and are not "difficult" to work on like the dealers & the uninformed would have you believe.
If you can turn a wrench with your hands, you can work on cars. One does not need to be mechanically inclined to execute this list.
There's also lots of support on these forums. I've owned 5 Rovers myself, and this forum has been a life saving source of information on more than one occasion.
Don't be afraid to ask for help!
To answer your question- a reputable shop like a dealer would charge at least a couple thousand for that work. A reputable indy might charge you 50% - 75% of that.
