Master brake leak
Old Feb 2, 2014 | 08:58 PM
willrok13's Avatar
I just completed the repair kit method a couple weeks ago. The only thing I would suggest is taking the hard lines off the master cylinder and running some fluid through, then reattach the hard lines and go to town bleeding. It's a nightmare to bleed. At least it was for me. But it's all straightened out now. Took about two of the big bottles of brake fluid.
The other difficult area was replacing the o-rings on the plunger that goes into the booster. That whiteish-yellow cap was a nightmare to remove.
Old Feb 3, 2014 | 06:59 AM
marshman442's Avatar
Thanks for the response. Any special tools required for the repair?
Old Feb 3, 2014 | 09:02 AM
willrok13's Avatar
A vise helps once you get the master cylinder off the booster. That's about it.
Old Mar 23, 2016 | 12:45 PM
tommyg99Rover's Avatar
Default Brakes leaking
The ABS pump comes on and off after every stop and go, is this normal?
Old Mar 23, 2016 | 01:28 PM
DiscoCam's Avatar
No it is not. I suggest starting a new thread because your issue is not related to the Master Cylinder.
Old Mar 23, 2016 | 03:14 PM
OffroadFrance's Avatar
I believe the reservoir sits on a rubber grommet arrangement which leaks over time. By the sounds AB appear to do a repair kit.
Land Rover Brake Master Cylinder Reservoir Repair Kit Disco I 94 99 STC2904 | eBay
You can see the grommet in this photo.
Old Mar 23, 2016 | 03:16 PM
But don't buy this one as I used the photo as an example and this is for a D1 NOT a D2.
Old Mar 23, 2016 | 03:38 PM
PalmettoDisco's Avatar
Power Brakes in Australia have the individual replacement grommets. Approximately $16 in US dollars plus international shipping. If you can wait on shipping.
Power Brakes for Hydraulic Brake Components
SolAeon
Jul 10, 2012 09:05 AM
troubled
Nov 10, 2010 10:23 AM
ajh
Oct 26, 2007 02:58 PM
larry99discoI
Aug 22, 2007 02:35 PM
leebuhrul
Feb 26, 2006 03:38 AM
