Milkshake oil in rear differential
When checking the oil in the rear differential, I found that it was almost empty so I added a quart. When I stuck my finger in the hole to check the level, I found that the oil looks like it has water in it. After looking around, it looks like oil is leaking out where the rear prop shaft goes into the differential. Could this also be the source of water or do I have two separate problems?
Ya I got stuck in a creek once for an hour and it flooded both my diffs with water. The 4 seals on the axle are the bearing seal (the one you described) , the 2 hub "O" rings and the breather on top of the axle.
If oil can get out, water can definitely get in.
Changing that seal will take a few hours the first time around and you will need a gear puller to get the assembly off if I remember correctly.
I am going to agree with this. Had same problem with front diff. The vent tube was clogged. I also have a slight leak on the right axle seal, if oil can get out.. other stuff can get in. Changes the front diff fluid twice in 1000 miles as kind of a flush. Cleared the tube.m. been clean ever since.
