Misfire, Compressions good, new wire & coils, Now What?
You make a good point about the connector. Which connector would just affect one cylinder?
But it happened the afternoon after the engine cleaning, which is very suggestive. It would make me very slow to think worn lobe or another mechanical issue. Electrical is much more likely.
Injector is a good place to start. I'd also probly break out the wiring diagram to check all the wiring that affects the spark and fuel flow to #5.
If you have it narrowed down to one cylinder then i'd say swap the plug wire too and see if that changes the missfire... if not and the plug/coil/spark and compression are good, it leaves the injector.
i was suggesting putting the dielectris in the cps sensor. plug or anything else down there that might often get wet.
I know of a guy who had misfire issues. He swapped plugs, wires, etc but the problem stayon on the same cylinder. After some more trouble shooting he replaced all of the injectors but still had the same misfire. He finally noticed that the back of one of the fuel injection wires, close to the injector, was rubbing and it was shorting out.
Once he repaired that part of the wire his misfire was gone.
Something to consider when trouble shooring your misfire, pay really good attention to the wires for the injectors.
If the injector and wire harness check out, then this is my next step
Ok found the problem, almost. My exhaust valve is not opening on cylinder 5.
When I was checking the fuel injector I figured I'd pull the Valve cover and rotate the engine. My intake side opens but the exhaust side doesn't. I was able to move the valve with a pry bar and watch it come back up so it's not a stuck valve. Now I'm down to a bent push rod, hydraulic tappet is bad, a clogged channel going to the hydraulic tappet or a worn lob on the cam.
I don't think its a worn cam as this was sudden and the I don't think its a bent rod but I'm going to pull them just to make sure. I'm leaning towards the tappet or a clogged channel to the tappet.
Do you guys know how I can check the channel to the tappet?
And there it is....(see pic) Pulled the lifter out and its worn bad. Turned the engine around 3 or 4 times (just to be sure) and the lobe on the cam is gone too.
I'm guessing the valve was stuck closed and caused this..? Whatever it was it happened quick. Anyways... the Rovers done. I'm not going through the crap to replace the cam. Parting out a Land Rover in Denver, CO.
