Misfires on 2001 Disco II
My disco is showing codes for a misfire in cylinder 5 and the P0300 for multiple/random misfires. Is there anyway to pinpoint this problem. I am ordering new plugs and wires b/c they look old and I do not know if they have ever been replaced (I have only owned it for 2 months). Is this most likely a wire problem or should I be concerned with the coil or MAF? The multiple misfire code is throwing me off and I would like to order anything else I need at the same time. Any help would be greatly appreciated.
42,000mi on the disco. I was searching the the forum for insight on the plugs and wires, looks like the magnecore wires, 8mm. I haven't decided on the plugs, any suggestions? The sad part of this is that in less than three weeks I am starting an apprenticeship at a LR dealership and I will get a discount. After reading the forum, it sounds like there might be some better parts than what I could get there though. Thanks
Well, you may get a discount, but Magnacor wires are far better then the factory wire ever were.
Some people swear Champion plugs are the only way to go, specifically the plugs sold by the dealer, but I believe the Bosch Platium Plus 4's are better and less money.
Your coil isn't causing this problem nor is the MAF, by the way, don't try to clean the MAF or you will be buying a new one.
Your favorite old retired Rover service manager.
