Mods to do while engine is out?
Hello,
I am in the middle of an engine overhaul on a 1999 D2 and want to really do it right and just once. I am not new to engine rebuilds, however I am new to Land Rover. What mods should I do while the engine is out? I am looking for advice like what unnecessary parts to remove, what to bypass, what to smooth out with a dremel etc. What I am doing/ have purchased already: Top Hat Liners, refurbished heads, new crank and rod bearings (4.0 liter), all new gaskets, new oil pump gears, timing gear and chain kit, water pump, camshaft (4.0 Liter), lifters, cam bearings, thermostat, and input shaft seal on trans(just because its easy now). Big thanks in advance! |
Hope you went with an aftermarket cam, or at least a stock 4.6 cam. I also always recommend a good port and polish on the heads and intake manifold, really wakes it up. I'm a fan of my headers too, but that requires replacing the whole exhaust system and making a better intake like what I've done to see any gains from the headers.
Add an oil pressure sensor on the spare port on the timing cover. Not a bad idea for these motors and on your '99, that is the only place it can be done because it has an oil cooler that takes up the other two ports. Also, this is really only possible to do with the fan, belt, and pulleys out of the way so you have a great opportunity now. Just did it on my '04.
Not really a mod, but not a bad idea either: change out your water pump with a brass impeller unit. |
Originally Posted by Alex_M
(Post 560331)
With all of your modifications, do you have the ECU re-calibrated? Thanks! |
Originally Posted by DiscoCam
(Post 560363)
Not really a mod, but not a bad idea either: change out your water pump with a brass impeller unit. I have purchased a pump with a brass impeler but didnt know its good :) what is the advantage? btw the brand is Airtex and atlantic brittish sold it to me as land rover oem. I was expecting Land Rover logos all over it but now i dont know what to think. Thanks! |
I don't know about the older models (I have a 2003), but I'd recommend looking into relocating the coil packs. I had one go bad on me, and realized I'd have to pull the whole SAI system and intake manifold to get access to them on mine. I didn't think of relocating them until after I had someone replace them (daily driver).
If that's applicable, do. it. Are you planning on putting in a lift or new shock towers? That would be a good candidate with the engine removed. Much more space to work. Replace both sets of oxygen sensors? The front sets would be easier to reach without having to work around a whole engine(especially the driver side). Planning on penetrating the firewall for lighting, lockers, and the like? Again, no engine in the way. I can't think of anything else offhand, but I'm sure people more familiar with the 4.0 can. |
Originally Posted by LandRoveris
(Post 560536)
Ok i will add the oil press. gauge for sure. Do you know if its true that the original coolant temp gauge cant be trusted?
I have purchased a pump with a brass impeler but didnt know its good :) what is the advantage? btw the brand is Airtex and atlantic brittish sold it to me as land rover oem. I was expecting Land Rover logos all over it but now i dont know what to think. Thanks! Coolant gauge cannot be trusted. It just simply will not do. However, adding a temp gauge is much easier than the oil pressure gauge. Motor can be in for this one. Alex_M did a good write-up on how to install a gauge on the top cooling hose as close to the plastic tee as possible. Look for his small modification thread on this forum. I ended up installing one as well so if you'd like, I can upload pictures. |
Originally Posted by jwigum
(Post 560553)
If that's applicable, do. it. Are you planning on putting in a lift or new shock towers? That would be a good candidate with the engine removed. Much more space to work. Replace both sets of oxygen sensors? The front sets would be easier to reach without having to work around a whole engine(especially the driver side). Planning on penetrating the firewall for lighting, lockers, and the like? Again, no engine in the way. I can't think of anything else offhand, but I'm sure people more familiar with the 4.0 can. Awesome. I will do all of these. Thanks! The lift is already on the car but the other items are great. Would you happen to know where is the best place to drill holes in the firewall for ease of access on the interior side? I would put grommets and plugs in there until I need them, or to put in gauges as mentioned by DiscoCam. |
(Post 560557)
Brass impeller pumps tend to last longer than the other pumps. IDK why. This is considered the way to go for water pumps on this forum. Also, Airtex has a great 2 year warranty.
Coolant gauge cannot be trusted. It just simply will not do. However, adding a temp gauge is much easier than the oil pressure gauge. Motor can be in for this one. Alex_M did a good write-up on how to install a gauge on the top cooling hose as close to the plastic tee as possible. Look for his small modification thread on this forum. I ended up installing one as well so if you'd like, I can upload pictures. Thanks for the reply. Good to know the pump is a nice one. Seeing pictures of your setup would be great! Thanks! |
(Post 560557)
Coolant gauge cannot be trusted. It just simply will not do. However, adding a temp gauge is much easier than the oil pressure gauge. Motor can be in for this one. Alex_M did a good write-up on how to install a gauge on the top cooling hose as close to the plastic tee as possible. Look for his small modification thread on this forum. I ended up installing one as well so if you'd like, I can upload pictures. I would install a Ultragauge or other OBDII based gauge vs installing another temp sensor and gauge. The ultragauge gives you a lot of additional info with a lot less effort to install vs. another coolant temp gauge. |
