Most effective way to drain ACE?
I have been using a hand-pump but I want a more effective way to swap out the ACE fluid.
Should I just take off the reservoir hose, point it down and shake the car side to side until it doesn't pump anymore fluid out of the hose? Sounds like a pretty ghetto way of doing it but I'm up at college and don't exactly have a ton of tools to work with.
I've went through around two full bottles of fluid and it still comes up dirty after 5 minutes of driving.
and if you want to flush your system too bright pink it is going to take you a lot more than two quarts. treat it as you would a transmission, plan on changing it all out over a period of time.
get a turkey baster pull out a quart from the pump and replace it every couple weeks, until its clean enough.
or your going to need something like a hawkeye that will do an ACE bleed
hilltoppersx
ROAMING WITH FRIENDS
12-07-2010 05:48 PM
