Mounting lights on stock bumper
Old 11-30-2011, 08:55 PM
ebg18t's Avatar
Default Mounting lights on stock bumper
I like to get to a few fishing spots well before sunrise. So I need more lighting. I was looking to see if anyone has mounted lights directly onto their stock Discovery bumper?
I don't need a winch/ new front bumper for my 04 discovery yet. just need an option for more lighting. Suggestions?
Old 11-30-2011, 10:17 PM
yloDiscoII's Avatar
Here's what I did...nothing fancy, just drilled holes and bolted them up with the included hardware + some extra washers for extra support.
Old 12-01-2011, 07:38 AM
That will work, bit there is no bracing in the front bumper and the lights will shake a lot when driving.
Old 12-01-2011, 07:49 AM
JEFIII's Avatar
This is the best, simplest and least expensive way to mount lights to you DII. This is the Simbar light bar from John Craddock's in the UK: <http://www.johncraddockltd.co.uk/products/gad211_light_bar_discovery_2_by_simbars.php>
Shipping was just under a week from the UK. Can't beat it. PM if you would like pictures and more information. John
Old 12-01-2011, 04:42 PM
ebg18t's Avatar
Installed pics would be great.
Old 12-02-2011, 09:43 AM
JEFIII's Avatar
Default Simbar Light Bar Pictures
Here are some shots of the Simbar Lightbar that I discussed in an previous post. Very easy installation. John
Attached Thumbnails Mounting lights on stock bumper-dscn1529.jpg   Mounting lights on stock bumper-dscn1530.jpg   Mounting lights on stock bumper-dscn1531.jpg
Old 12-02-2011, 10:12 AM
MU ///M3's Avatar
JEFIII - how did you wire the lights into the cabin, and how are they switched?
Old 12-02-2011, 05:04 PM
ebg18t's Avatar
How stable are the mounts? How does the bar mount to the bumper?
Old 12-03-2011, 07:19 AM
JEFIII's Avatar
MU//M3: There are many wiring diagrams and switch suggestions on the forum and also on Dicoweb.org. You just have to search and decide what works best for your application and capabilities.
ebg18t: The Simbar mounts to the Bumper itself with included hardware. It is perfectly fine for it's intended application as a light bar, but I wouldn't reccomend it be used as a pushbar. Hope this helps. John
Old 05-22-2012, 04:45 PM
dparham's Avatar
what about using this? it holds weight in shower and water proof! hmmmm and CHEAP! $24-$35! free shipping My measurement for Disco 2 is 29" and I can find the 30" and if in middle 12-18" id think but its really close to the grill and not sure lights would fit.... just an idea...
http://www.amazon.com/Kingston-Brass...sr=1-3-catcorr
http://www.wingits.com/assets/images...REV-092509.pdf
Quick Reply: Mounting lights on stock bumper
