Mud in Diffs
Mud in Diffs
Hey guys, I changed out my diff fluid a couple of days ago and on both drain plugs there was about a half inch of muddy/gritty stuff in addition to a quite a bit of metal shavings. I replaced the fluid with Royal Purple 85/140 for more protection but I am worried that I have a ticking timebomb on my hands. Should I be worried about this, and also what is the muddy stuff anyway. Thanks alot
RE: Mud in Diffs
Sounds like your diff fluid was never changed before. I would drive it for a week and then change it again.
Did you change your t-case too?
That muddy stuff was just years of sludge.
You might want to use cheap fluid in a week, drive for a 1,000 miles and then change back to full synthetic.
RE: Mud in Diffs
Thanks for the quick replys. Well I always had Land Rover do the Servicing up until about a year ago when I started to do it myself. The diff fluid should have been changed at the 90,000 mile service (roughly 30,000 miles ago on the truck) that I paid a grand for, but hey I have been ripped off before [:@]. How do I go about checking if the diff vents are clogged? Thanks alot for the help.
RE: Mud in Diffs
I just replaced my axle vents, the front seal on my rear diff was leaking, replaced the vent and no more leaks. So that's how I knew my was clogged. You might just want to replace them and be done with it.
I believe that you can buy both from Atlantic British for under $50. Very easy to replace.
I do not know how to tell if they are clogged.
