My cooling issue identified
As many of you know I have had a cooling issue since my head gasket change. I have had a number of threads re this but thought I would collect everything in one Troubleshooting thread that might help someone else.
It is the Rad by the way completely clogged.
Prior to head gaskets the Disco ran 188.6 to a max of 201 - other than load slow offroad uphills in low range a 5kph reached a max of 215 over 20 minutes - dropped to 176 as soon as I was moving quickly
Post head gasket I did do a cooling system flush - Prestone and water
Running Zerix premix AF
The issue
This is always difficult with cooling system as you can not see what is going on, I purchased an IR Thermometer. reaching past a moving fan is not a good idea
It was noted by @shanechevelle and @redwhitekat that a compromised thermostat can produce the same issue on a Disco. This makes perfect sense given the location of the thermostat on a Disco, however mine was working perfectly prior to the work done. It is in the realm of possibility the cooling system flush has dislodged material which is preventing the correct operation of the thermostat. I find this unlikely but I will investigate once the system is apart.
My reasoning here is once the Disco has hit the open temp for the thermostat, it is open and coolant should flow normally, I would expect yoyoing of temps rather than an continuing increase in temps. None the less they both have a valid point, and thermostat needs to be confirmed to not be the issue.
While I may well flush this rad, to see if things improve I will be ordering a new one. If the old one cleans up it will become an emergency spare.
The issue
- The Disco runs fine at highway speeds temps between 188.6 and 194
- Any load increase temps generally to 197.9
- Idle temps run up to 206
- adding A/C makes thing worse - recent test (today)
- Confirmed hoses were not rock hard and no coolant being expelled (catch bottle on overflow line)
- Bled cooling system fully so there are no air pockets
- Checked belt routing just in case I managed to get it wrong
- Checked the fan,clutch and shroud
- Did an A/C test quick increase in temps
- Heater core
- Water pump
- Radiator
- Thermostat
- Start the disco and check the coolant tank for movement of AF, the throttle body coolant line will cause the AF to move in the tank, if it does not your water pump may be the issue. In my case normal movement, so the water pump is likely still working well
- Next check the hoses for firmness while the engine is running and at temp they should be firm but squeezable, firmer than cold.
- Next check the hoses with the engine running, you will not get perfect temps with the IR but you will get differentials. I started with the heater hoses, 10 to 15 deg F diff with min fan. There may be some clogging but nothing earth shattering.
- Checked the main lines with IR top hose to rad 150 bottom hose 62 there is a big problem. Engine temp was at 197.
- Shut down the Disco checked the lower rad hose by hand - cold to the touch upper hot to the touch
- There is a final test you can do the check the water pump, but you need an assistant. Pull the top hose, extend it so you can catch the coolant and crank the Disco over. You should get a good pump of water out. DO NOT RUN THE TRUCK FOR MORE THAN A SECOND, IF IT STARTs SHUT IT RIGHT DOWN
The following 5 users liked this post by Richard Gallant:
DiscoID (04-23-2020),
jastutte (05-08-2020),
Sixpack577 (04-23-2020),
The Deputy (04-23-2020),
whowa004 (04-23-2020)
Originally Posted by Richard Gallant;726892
[b
[b
The issue[/b]
piperff (05-24-2020)
Lower hose was 62 and it's the rad?
If the temps were normal before the gasket change and messed up after how can it be the Rad? It didnt just clog like that overnight.
Borrow a bore scope.
Empty the rad.
Take off upper hose.
Insert scope down into rad.
Post pictures of the core.
I would sooner guess the little holes in the thermostat would be clogged before the radiator core.
190-208 is acceptable.
Empty the rad.
@shanechevelle it could be the thermostat, it is on my list of things to verify when I pull it apart. You may have missed the part about doing a rad flush after the head gaskets, once the thermostat fully opens the engine should cool normally, it does not. It is possible the thermostat became compromised, I have an inline kit coming as well. But I expect the top of the of rad to be the issue.
I will update this thread once everything is checked
@shanechevelle well I got things apart today and there is definitely something up with the old thermostat, When I used smooth end of a drill to check the 4 holes in my grey softspring it took a bit of force on a hot thermostat to move things it was like the spring was bound up. It also does not seem to open correctly warm.
The old rad "seems" ok, but I suspect some blockage but I have a new one and it is going in. The Sai sensor was covered in what looked like "mud" cleaned up fine though.
I have both a Black 78 and Extinct's in line kit, I am going with black of now as I have some ideas on mounting the inline I want to play with and the switch over is only an hours work.
Well started her up 183.5 to 185 ish running the black 78C LR thermostat idling for 20 minutes - no driving to build temps yet.
@Extinct I will - I will log engine temps for the next little while. Even if stay with black LR for a couple of months your kit will be my trail spare, I have hoses sitting waiting to be used for the inline install.
