My cup holder!!!!
Ok well i had originally assumed you were talking about the large one mounted on the center console to the left and right of the shifter, now is sounds like like you're talking about the center dash ones. I pulled mine all the way out once and all it took to get it back in was to close the cup support on the bottom and slide back in. Just looked through the rave, couldn't find any drawings of taking that part when removing the dash and yes the cup holders are the biggest problem. What else would catch all the rain water from my sunroof haha seriously going to fix that though.
You may have to turn the little mechanism on top (see your second picture) so that it lines up properly with the stud hanging down from the inside top of the hole you're inserting the cup holder into (see your first picture).
If it isn't broken, that mechanism (when correctly inserted) should act as a guide to allow the cup holder to move in and out without falling out of the dash altogether. (Note: I couldn't tell from your picture, but there might be a spring involved too. It might be worthwhile to try gently removing the coin/ash tray as I think it has a similar mechanism...) If it (the mechanism) is actually broken and you're really determined to fix the cup holder, then I'd call Will Tillery and see if he has one he can send you out of a wrecked DII.
Better yet, given that the stock cup holders are pretty much junk, if (when) you get this one back in to place, I'd suggest that you consider installing a set of these big cup holders available from AB and other Rover parts suppliers. I put them in my DII and haven't touched the stock cup holder ever since...
