My month-old window regulator is broken!
I'll check tomorrow. I think it's Terrafirma, but maybe Britpart.
jacobmstein (12-24-2020)
I replaced mine last year and it has held up well for far. I know it is a Britpart where the product quality can be suspect at times. But it has held up well so far. Not bad for the entire assy and motor for $85.
https://www.ebay.com/itm/LAND-ROVER-...item236f95b18b
Good luck!
Good luck!
Good luck!
Good luck!
I replaced my new window regulator and new motor with this from LRNJ about 10 months ago (strange, they have now priced it at $2K):
https://www.ebay.com/itm/LAND-ROVER-...a0a000b4700005
Well, it is no longer working. Same affliction as the video posted by the original poster (jacobstein) in the video above.
I took door panel off, checked the window regulator and motor. The 10 month old motor still works. I check the teeth of the 10 month old regualtor assembly. Still in great condition. The rollers are round and not broken. The tracks are lined with grease. However, the regulator keeps getting stuck and over-extended at the bootom, and won't raise up.
Any ideas on what to check next?
