mystery unhooked wire
here is a random wire i saw hanging not connected to anything it is under the passenger side door between the front and rear door. it looks original, any clues to what this is?
http://inlinethumb43.webshots.com/14...500x500Q85.jpg |
Dont worry about it.
You dont have SLS (self leveling suspension)do you? |
no, would that be the hookup for that nightmare if i did?
That is not an SLS wire, they are on the drivers side.
Originally Posted by hilltoppersx
(Post 127807)
the mystery continues. when i'm feeling up to it i will follow the wire up to the engine compartment see where it goes. right now more worried bout the drive shaft problems... thanks
Passenger side would be for ACE correct?
The ACE pump runs off the engine, the serp belt runs that pump, it is like a power steering pump.
Wouldn't that be the electronic signal for the rear ACE cylinder which mounts under the pass side? Just guessing.
Sure is possible
