mystery unhooked wire
Old Jul 19, 2009 | 05:15 PM
hilltoppersx's Avatar
Default mystery unhooked wire
here is a random wire i saw hanging not connected to anything it is under the passenger side door between the front and rear door. it looks original, any clues to what this is?
Old Jul 19, 2009 | 06:17 PM
Dont worry about it.
You dont have SLS (self leveling suspension)do you?
Old Jul 19, 2009 | 06:22 PM
no, would that be the hookup for that nightmare if i did?
Old Jul 19, 2009 | 07:19 PM
That is not an SLS wire, they are on the drivers side.
Old Jul 19, 2009 | 07:30 PM
I dont know for sure, but I was helping a friend work on his DII and he had the same unhooked wire harness and he does not have SLS either.
Old Jul 19, 2009 | 09:48 PM
the mystery continues. when i'm feeling up to it i will follow the wire up to the engine compartment see where it goes. right now more worried bout the drive shaft problems... thanks
Old Jul 19, 2009 | 09:58 PM
DavidG's Avatar
Passenger side would be for ACE correct?
Old Jul 19, 2009 | 10:13 PM
The ACE pump runs off the engine, the serp belt runs that pump, it is like a power steering pump.
Old Jul 19, 2009 | 10:22 PM
DavidG's Avatar
Wouldn't that be the electronic signal for the rear ACE cylinder which mounts under the pass side? Just guessing.
Old Jul 20, 2009 | 07:17 AM
Sure is possible
