Nanocom question (US)
![](https://cimg3.ibsrv.net/gimg/landroverforums.com-vbulletin/2000x1000/screenshot_20191027_125030_4d40fbdd4b5c89a5b099facf63caef7e2821b799.png)
You will definitely need 2 unlock codes for the Discovery 2 Bosch V8 4.0/4.6L:
- #NCOM15 which is the Nanocom unit, OBD cable and the Range Rover P38/Discovery 2 Motronic Petrol V8 unlock code to access the Engine Control Unit (ECU) functions.
- #NCOM13 is the Discovery II Systems unlock code to access of the Valeo BCU, Lucas ACE system, Bosch autobox, TRW Airbag system, and RR P38/Discovery 2 Hella Cruise Control. For the all other unlock codes, you can purchase and download from the Nanocom site and they don't take PayPal. Here's a hint... I found it cheaper when I bought the unlock codes in Euros without VAT.![Thumbs Up](https://landroverforums.com/forum/images/smilies/thumbs.png)
Another Discovery 2 option which @Sandman614 mentioned is the #NCOM11 and is only for TD5 Diesel engine owners.
USD 425.78 NCOM04 - The unlock codes included in this kit will activate the software for the following Petrol V8 Discovery II systems: Motronic V8 engine management Discovery II, SLABS (Self Leveling and ABS), BCU, ACE (Active Cornering Enhancement), Auto box and Airbag. Please see the Products page on the web shop for more detailed information of the capabilities with each ECU.
USD 63.44 NCOM13 - This unlock code adds the SLABS (Self Leveling and ABS), BCU, ACE (Active Cornering Enhancement), Auto box and Airbag to the Nanocom Evolution
USD 63.44 NCOM15 - This unlock code adds the Motronic V8 petrol engine management to the Nanocom Evolution where not already included. It can be used on either a P38 or Discovery II model. Please note that while you can access the Motronic engine management on the P38 with the Blue OBD lead, you will require the Green OBD lead NCOM023 if you intend to also add the rest of the P38 systems if you only have a Blue OBD lead or indeed an LD024 CAN BUS lead
Below is what I ordered and I have all functionality on Discovery 2 V8 Petrol USA. Those noted unlock codes above to purchase separately are to add to your current Nanocom.
Code: NCOM04
Quantity: 1
Description: NANOCOM Evolution for Motronic V8 Discovery II kit
Weight: 665g
Price: 425.78 USD
Code: NCOM04
Quantity: 1
Weight: 665g
Price: 425.78 USD
Brandon318
08-27-2019 03:02 AM
