Need guidance on battery draw readings please
Old Mar 27, 2019 | 11:21 AM
bcurtman's Avatar
Default Need guidance on battery draw readings please
Drove to work after being on charger last night. When I got ready to leave work at 5, it was dead. Jump box got me going. When I got home I checked it out pretty thoroughly as follows.
Charging 14.2
Shut it off, battery holds 12.8 Battery is a known to be good one.
Started the milliamps test with my Fluke set on 30mA scale and connected between unhooked battery ground and battery ground post
About 46.2 mA consistent draw. Barely enough to flicker a 12 volt tester
Pulled every relay and fuse in the engine compartment panel one at a time with no more than 1 or 2 mA total change
Unhooked lead to alternator. No change
Wife got home. Asked her to watch the Fluke while I pulled the fuses on the drivers side interior panel
Opened the door and it went to 400+ mA
Thought I'd hold the door switch while I pulled fuses. Silly me, it doesn't have a typical door switch, and I couldn't find it....
Closed the door. Draw stayed up around 290mA. Cycled the key and closed the door. Dropped back to 46.2mA
Opened the doors and made sure every dome light was in manual off position. Unplugged ultragauge. Cycled the key. Closed doors and it stayed at 290.
On a whim, I hooked battery ground back to battery and pulled it back off and checked draw. 27mA
Opened door and cycled key. Back to 290. Went to feed cows, gone 30 minutes or better. Still 290. Everything was off, key out of ignition, dome lights off, doors slammed. Never got it back to 27, which I suspect is approaching acceptable. I noted that cycling hood switch by hand jumps it up.
Put it on a 2 amp charge and came in for dinner. Gonna get the rave open on my tablet. (electrical section)
I'm thinking at this point its the door switches or security system. Looking for some help / guidance / been there done that, please...
Old Mar 27, 2019 | 11:35 AM
Ben Matheson's Avatar
Pretty sure bcu retains power for a couple minutes after door is shut...
Load test the battery...
Old Mar 27, 2019 | 02:14 PM
bcurtman's Avatar
I just swapped in a 'known to be good" battery last week to eliminate that option. If I unhooked the hot lead to the alternator and there was no amp draw drop, doesnt that kind of eliminate the alternator as well?
Old Mar 28, 2019 | 07:31 AM
bcurtman's Avatar
Since nobody has come forth, can anyone tell me if pulling fuse 21 in the interior panel to disable the door locks will help eliminate a faulty door switch?
Old Mar 28, 2019 | 10:36 AM
bcurtman's Avatar
Well, that does'nt work. Pulling fuse 21 does not allow one to shift from Park. Back to the truck and back to the drawing board. Anyone?
Old Mar 28, 2019 | 11:43 AM
Best4x4's Avatar
Everytime the vehicle is unlocked/opened or a key is cycled the ECU/BCU wakes up. Can’t remember how long it stays active though.
Old Mar 28, 2019 | 02:34 PM
Motorhead1's Avatar
Only variation on milliamps readings that I find to be different in your original post was: You cycled the key and closed the door and the draw went to 46.2mA. All the other times you were at 290 after cycling the key and closing the door. Maybe try opening and closing each door without key cycling? See if anything reads different? idk. Your definitely on it. Good luck
Old Mar 28, 2019 | 02:58 PM
Best4x4's Avatar
I’d trick the hood switch lock it up and close it up like normal & check back in a few hours to see if the ECU/BCU went to sleep.
Old Mar 28, 2019 | 03:13 PM
bcurtman's Avatar
In theory, should I be at 0 mA draw when the ECU /BCU go to sleep; or is something always cooking. I guess clock...anything else?
Does anyone know what "normal" at rest amp draw is? I reckon there are no "normal" rovers then though now are there!
Old Mar 28, 2019 | 06:52 PM
Motorhead1's Avatar
I hear my ABS pump faintly buzzing a tiny bit, clock and who knows what else is always alive.....
