Need help with P0305 before this thing becomes a boat anchor.
Old 11-22-2013 | 06:59 PM
DiscoDubs's Avatar
Had same thing happen with p0305 and occasional 0303 and 1300 mixed in there. Changed out my upstream O2 on that bank and problem was gone. My coil pack has been floating around unbolted for awhile now so I thought along the same lines as you.
Old 12-19-2013 | 04:58 AM
ratijs100's Avatar
can you tell how did you make compression test? I will unplug or spark plugs and wires, pull out pump relay, but what to do with the ignition? Its too narrow and can not reach connectors to unplug them from coils without removing upper intake. how did you manage to turn off the ignition?
Old 02-06-2014 | 02:42 PM
dmatranga's Avatar
@ratijs: Ever figure this out? What was the problem?
Old 02-06-2014 | 03:22 PM
jfall's Avatar
You have the wrong plugs in the truck.
All these Bosch gimmick plugs with a small tip - junk.
Put in OEM plugs.
The plug you have in there is not burning hot enough.
It is black.
no wonder it misfires.
Misfires can also be caused by sticking valves.
Old 02-06-2014 | 09:21 PM
Rover2013's Avatar
Is it possible that the fuel injection system is at fault with higher ethanol in fuel causing rust
I would do a alcohol test. Just a thought
Old 08-29-2014 | 10:53 AM
ratijs100's Avatar
Engine compression test showed no leaks and compression was in good range for all cylinders. I think it might have been that on the cold start before the engine reached optimal temperature, I was accelerating too much and there was overload on engine causing misfires or it might have been fuel issue. Engine compression test is good way to start as it excludes many reasons for misfire.
GURU06
05-24-2021 03:43 PM
Britchick1980
07-03-2014 06:21 PM
Dan_da_LR3_H2_man
03-05-2014 01:24 PM
BIG g
06-14-2010 02:44 PM
Fivespddisco
Off Topic
01-26-2010 07:18 PM
