Need ideas on timing chain problem
I spent the weekend replacing timing chain and gears, oil pump, water pump, oil pan gasket, valve cover gaskets, ignition coils and wires. Drove for about 5 mins and right when pulling into the driveway oil started coming out pretty good. Not sure but looks like it came from the timing chain cover. I noticed when started it was kinda rough running, would kinda back fire when gassing it but seemed to level out smoothly, any ideas or suggestions would be very helpful, ty
power steering fluid also leaks from the front. driver side dish. how is the PAS fluid level? you could have disturbed the hoses when you removed the cover. I assume you did move the PAS out of the way.
