New Brakes; Hard to Stop, Pedal Goes to Floor
Hello,
I have been a viewer of these forums for quite some time now, but have never bothered to register until now. I was hoping I could get your help on my brake issue. My uncle replaced my brake pads on my 2001 Discover II earlier this morning. He had to leave immediately after he finished so I feel like he might have rushed through it. My brakes are worse now than they were before! the brake pedal goes all the way to the floor, the car is difficult to stop, and i feel a slight pull every once in a while. He says it could be air in the system, what do you all think? Thank you for your help
No, I pumped the pedal after he left for quite some time. I then drove it to class and back and the brake pedal is still very loose.
If all he did was replace the pads, there's no reason air should have gotten into the system. Did he disconnect the brake lines for some reason? If so the brakes would have to be bled to remove any air that would have gotten into the system.
Tony Crosland
Feb 27, 2013 03:45 PM
marlymarl
Apr 21, 2012 12:49 PM
