New Discovery Owner with two issues
Actually its not a regular dealer. These are guys that just sell cars and they are mechanics too. They seem honest and been helpful with some other minor issues.
Oh okay, I thought you meant the Land Rover stealership! That's always a bad idea!!
If these guys are legitimately good people and you're sure that the lifters were done, you should ask them if any of the lifters were bad or if they just changed them because they SUSPECTED they were causing the tick. The lifters are actually really good quality in our engines and rarely, if ever, fail from what I've heard. Mine's got 145,000 miles on it and all of my lifters are in great condition even the one that had the cam bearing rubbing against it for about (at least) 10,000 miles. Having said that, I'm not so sure about slipping liners either. I had heard so much about this happening that I half expected to have one or two slipped liners in mine when I got the heads off but, no none of them slipped. I think that's more the exception, not the rule with these engines. Chances are, if everything in the heads and lifter valley looks okay (meaning, rocker arms, rocker shafts, lifters, push-rods, etc.) and you have no slipped liners, and oil pressure readings are good, it's probably just piston slap. The only thing that will fix that is new pistons to replace the ones with collapsed skirts. Good Luck, I hope you get it figured out! Keep us posted on your progress, and don't get too excited if it goes away for a few days sometimes, mine does that but always came back.
He told me it was gonk in the oil and he has to put something in there to get rid of it. Now he was ramdom guy, but he described the exact same symptoms. Ticking on idle and then when you speed up it goes away. It actually almost sounds like a rattle or tapping of some sort when I get closer to engine.
have you ever used the zx1 extralube?
I have not tried the zx1 extralube but, I tried many of the tried and true methods of gunk-removal to no avail. I think mine also had a rattle in it from time to time and I think that was caused by the cam bearing that fell out of the block and rattled around on top of the cam. This could be the same issue you're having, the unfortunate thing about that is, you have to remove the lower intake manifold to get to the lifter valley where you can see the cam and lifters. Here's a picture of the cam bearing I pulled out of the engine after about 10,000 miles of running with it in there. I also had a few little flecks of metal in the oil when I changed it a couple of times in the past few months. I'm pretty sure that it was little chunks of this bearing settling in the oil pan.
I have the same kind of ticking as well, however I just did a HG job myself and saw no such cam bearing failure, it all looked good for 125k. I did notice the ticking increase with engine speed but not with sync with it. What about SAI? anyone understand what its functionality is all about and if it could be the culprit?
Yosemite Sam I am
01-13-2014 11:47 PM
