New guy w/ D/S parts question
I want to make sure I dont miss anything - 01 Disc 93k original driveshaft. Just noticed slight shake in the wheel and 65+, very little but still concerned me. After reading the horror stories I am going to replace it right away, but want to make sure I get all the necessary parts for the job. Done lots of searching, just want a 1 2 3 parts list to get going on this. I have become very familiar w/ my rover over the past 2 months replacing such things as the timing gear cover gasket, water pump/gasket, valley pan gasket, new pulleys & tensioner, new belt, new t-stat......on & on....I am going to do this job myself, I think I can handle it. Like I said, I just want to order all the parts that are needed and get busy, thinking Tom Woods shaft, but need to know what else is necessary for the fix to be done properly.
Thanks everyone!
Thanks everyone!
I was just going to replace it. If the replacement is just one unit that is all I will need then right? Undo old and pop in the new? And if i rebuild I need the greasable U-joints and centering ball kit? Obviously the more expensive option of replacing it sounds much easier as far as DIY. How bad is it to rebuild the old one by yourself, and how much time? I am pretty mechanical, but time is hard to come by.
Thanks guys.
Thanks guys.
tom woods costs $350. if you want to do it yourself its about $50 in parts and 2 housr labor unless you get stuck with the centering ball kit which can prove problematic. some people bring it to a drive line specialist and for $100 have them do the labor and then do the install themselves...
To rebuild yours:
From Advance Autoparts
3 each - Neapco/PDQ 1-0005 u-joints @ $13 ea
1 each - Neapco 7-0081NG centering kit @ $29
Instructions at http://www.discovery2.co.uk/propshafts.html
Replace:
http://www.greatbasinrovers.com/ (web site sucks so you need to ring)
or
http://www.4xshaft.com/index.html
Replace:
or
roverintherocks
12-08-2010 10:36 AM
