New Member...NEED HELP!
Old 08-05-2021, 10:14 AM
Dave03S's Avatar
As long as your wife is open to spending some money on the rig you are good!!! But you most likely do not need a new engine.. But maybe a new battery and a new battery in the remote.
Do the stuff mentioned above...
Then I would invest in replacing the cooling system. All hoses, belts, etc. even the overflow bottle and possibly the radiator, but you don't need to do that before getting it running.
I would think you need to drain the gas tank and refill with new fuel.
Once you get it running address the power steering and update the cooling system.
Get a code reader. Many people use bluetooth OBDII apps, the UltraGauge, or one of the more expensive full feature diagnostic tools.
Good Luck!
PalmettoDisco (08-05-2021)
Old 08-05-2021, 10:20 AM
Richard Gallant's Avatar
Received 1,177 Likes on 814 Posts
@nysfinest318 the biggest thing with the engine is the cylinders as long as they are not seized everything else is not too bad to fix. You can safely go over the top on oil in the cylinders in the process I listed, but it makes a mess when you turn her over underpower without plugs.
Here is a link to a general guide https://www.hagerty.com/media/mainte...long-dead-car/
Old 08-05-2021, 05:39 PM
PalmettoDisco's Avatar
As mentioned, replace the gasoline (petrol), after that many years.
ekjdm14
03-14-2021 07:16 PM
mrcooper
01-28-2021 08:57 AM
Stangjunkie
06-05-2016 11:12 AM
zombiedisco
07-25-2012 09:01 PM
Hijacktheleft
07-06-2010 08:45 PM
Quick Reply: New Member...NEED HELP!
