New pads, and now no brakes and pedal to the floor.
Hi, I recently replaced my brake pads all round due to wear. Using a G clamp and a bar, I pushed the cylinders back in the callipers. This was tight but they went in. With all new pads fitted I thought I would have perfect brakes. Oh how I was wrong. Now I have next to no braking and my foot goes to the floor. I've tried the 2 man bleed but there seems to be no pressure in the lines to any wheel. Where do I go from here? I can't flush the system because the system won't take any fluid in, and it won't push fluid or air out of the bleeders.
I can have a go at gravity bleeding, but when I was trying to bleed earlier, there was no pressure at the wheels at all. Hardly any air or fluid run run through the pipe at all. In fact it looked to be sucking the fluid back into the system sometimes.
If there is no pressure, then is it the master cylinder not working, or the abs module not letting the pressure get past?
Should the abs module let fluid past under normal circumstances with the engine off?
If the pedal goes almost straight to the floor, is there anything to give the pressure?
Anytime you open the bleeder, you'll likely introduce air. If you just compress the caliper, bleeding shouldn't be necessary.
That said - maybe the abs system on these trucks doesn't like that technique. I'm a little worried that some valve in the modulator is blown.
Thank you all for your suggestions so far, but none of these seem to be working. Tried pumping fluid out at the modulator, and yes there was fluid from both pipes going in. Unfortunately there is still no pressure anywhere in the system.
Well Dr. No it doesn't look like its common practice for this poor guy. Tony take the cap off the master cylinder and do the two man bleed method start with the farthest caliper and work back to the front. It may take several rounds of bleeding before you get the brake pedal back. Make sure you top off the master cylinder once you start getting fluid at the caliper. When I changed the master cylinder on my truck I didn't bench bleed it so it took several rounds of two man bleeding.
