New Scanner under $200 reads OBD2 and ABS
Old May 13, 2014 | 07:47 PM
  #41
VTRover's Avatar
Received my Autel 619 unit today. The only fault it threw was the SVS error! Seems like an easy fix per jycsalas SVS modulator fix repair manual (OPTION B). Couldn't get it to connect for OBDII or SRS though. However, I'm not getting any dash lights other than the intermittent 3 amigos.
Does the engine have to be running in order for the Autel to connect to the OBDII?
Old May 13, 2014 | 09:49 PM
  #42
RandyH1221GJ's Avatar
Just need key on.
Old Nov 7, 2015 | 07:01 PM
  #43
Twix's Avatar
Bringing up an old thread, has anyone used the Terrafirma i930? I think I might pick one up soon.
Old Nov 7, 2015 | 11:03 PM
  #44
Bom2oo2's Avatar
Are you talking about icarsoft i930,?
Because if you are , I have one & for the money it's very good tool, does everything except reprogram computer & remote,,,
Old Nov 8, 2015 | 06:28 PM
  #45
Twix's Avatar
Yeah that's the one listed on British Atlantic's site. It does read ABS codes right?
I'll have to wait a month to order so I'll be home when it gets to my house.
Old Nov 8, 2015 | 10:04 PM
  #46
Bom2oo2's Avatar
Yes not only it reads ABS , it can also activate it if you want to bleed it,,
It can do just about everything but reset computer & remote,,
It's specialty tool for land rovers/ jaguars,,
I have also connected to other cars & it reads their codes & can clear them as well,
But not as detailed as when connected to my D2,,
You can check icarsoft i930 on eBay, it's at least $50 less than what they ask at AB.
Old Nov 9, 2015 | 07:27 AM
  #47
drowssap's Avatar
You can find them for as cheap 125 on ebay great little machine for the money.
Old Nov 1, 2016 | 09:53 PM
  #48
Matthew Desormeaux's Avatar
OBD II 2 VEHICLE CAR AUTO DIAGNOSTIC FAULT CODE SCANNER SCAN TOOL FOR LAND ROVER | eBay
anyone got any faith in one of these?
Old Nov 4, 2016 | 01:09 PM
  #49
squirt's Avatar
Sure, it'll work fine with your Torque app, just like the millions of other similar (often cheaper) dongles available. (hint: most don't have the words Land Rover in the title, but anything OBD2 compatible will work the same)
You'll get full access to ECU codes, lots of real-time data, but nothing having to do with ABS.
Old Nov 17, 2016 | 12:03 PM
  #50
CollieRover's Avatar
For the guys with the Autel 619. Are you able to monitor the ABS data as you are driving? I am having some issues with a speed sensor, and need to figure out what is going on without just throwing sensors at it.
